15 years agousing lvds
G´day !! I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This seri...
14 years ago --- Quote Start --- The serialisation factor in your system is actually 14. The ALTLVDS does not support this, but you could set it to handle a deserialisation of 7 bits and concatenate two 7-bit packets into one 14 bit. ALTLVDS however uses a PLL to sample the inputs, so if you have multiple devices, ADCs in this case) you may run out of PLLs. However as the outputs of the ADC are nicely source synchronous and are accompanied by a dataclock and a frame-indicator , you can easily deserialise the ADC data channels with simple shiftregisters. Feed the inputs into a DDR-In block and then serialise the 2 bits in a 7-bit shiftregister each. assemble the 2 7-bit buses into a 14-bit bus and define the right moment to register it. You need to do some work to constrain all this though. I have done this for ADS527x and AD9222 octal ADCs, unfortunately my code is in AHDL (I do use VHDL nowadays). --- Quote End --- I changed a way of using the ADC data clock and AD output to connect the inputs of DDR-In block directly(without PLL source synchronous mode), and there is also an invalid Fitter assignments as follows and I don't know why.
Ignored Entity:altddio_in
Ignored From:
Ignored To:input_cell_H
Ignored Value:HIGH
Ignored Source:Compiler or HDL Assignment
Ignored From:
Ignored To:input_cell_L
Ignored Value:LOW
Ignored Source:Compiler or HDL Assignment Although the above invalid Fitter assignment Warning appears, but I can find the ALTDDIO_IN module in the Technology Map Viewer. So does it mean that the above warning has no effect on the implementation of its function?
