15 years agousing lvds
G´day !!
I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This serial data (data rate for each serial stream is 700Mbps maximum) is read with Cyclon III. What´s the best way to do this ? I found the ALTLVDS Megafunction, but i think this block has no sense, cause of the serialization factor of 1 for each channel used in my system. But what´s the best way to read and process the sampled input data ?? Is it possible to wire this LVDS Serial data direct to a PIO ??? hope someone can help me greets !!!45 Replies
--- Quote Start --- Hi Jerry, I did some more study, and I believe you can have your cake and eat it :) IMHO it can work as you describe / have drawn. Almost, as you will have to feed one FCO clock instead of one DCO clock (per group of 3 aggregated ADCs). The ALTVDS PLL requires the base clock as input. http://www.alteraforum.com/forum/attachment.php?attachmentid=13057&stc=1 The FCO clocks of the three ADCs in each block will run at (exactly) the same frequency, but with an unknown phase-shift. But this phase-shift doesn't matter as the DPA circuitry in the receiver datapath will select the best phase for each data signal. It could be advantageous if you can match the trace lengths per group of 3 ADCs. The four groups can have quite different trace lengths. Also don't over-strain your self with matching the lengths between signals; 50 ps is about 7 mm trace length. Although IMHO it won't matter, the DPA will select the phase of the PLL clock to sample within 1/16 of the UI (or 62.5 ps in your case) of the ideal position. I would be careful though and also seek advice from the other Experts (FvM, Tricky, ... ?) too. Regards, Josy --- Quote End --- Hi Josy, Thanks for you reply me so quickly. This is the first time we use serial LVDS ADC devices in our applications, our previous ADC parts are AD9218 and AD9288. So i need study more and think more before we finish hardware schematic design. Your comments make me more confident. Is it better that use DCO as clock and FCO as word edge indicator? As lvds pins are enough for my case, and each ADC's FCO may be connected to FPGA. Furthermore, what is the skew effect among ADC devices in one group? I don't know if the convertion delay is consistent among differnet ADC devices? I don't worry about this among channels inside one ADC device. Actually, i'm study TI's ADS52J90 datasheet during i studying AD9633 (and AD9681, which must use 2-lane, will consume more lvds lines, and pass). Question is the input BW of ADS52J90 is only 70MHz. - Altera_Forum
--- Quote Start --- I'm going to using Stratix IVGX deivce, and have to use column I/O LVDS pairs to receive ADC output. --- Quote End --- Yes, column I/O LVDS pins would also be one of the solutions for our case. However, our system still use many normal I/O pins to interface other parts. So i have to group several ADC devices to save I/O pins resource. - Altera_Forum
--- Quote Start --- Hi Josy, 1. My FPGA part is EP4SGX230KF40C4. 2. If i use ALTLVDS megafunction, my fpga doesn't support 12 ALTLVDS modules. There are toal 4 altlvds module in EP4SGX230KF40. 3. Can the DDIO decrease the speed from 1000Mbps to 500Mbps after the ADC data come into FPGA? If this is the case, the register shift will run at 500MHz in logic. BTW, I have a thought, however, i don't know if this can be implemented. You know, i will group 3 or 4 AD9633 into a group. So can i only connect one of the group's ADCs DCO to fpga, and process them by using one ALTLVDS module as the attaced image shows. Then i can receive all 12 AD9633 by 4 altlvds modules. The key issue is if DCO connected to fpga synchronizes with other ADCs output data? If not, the logic design will lose relationship between clock and data. I can carefully route the clock trace to all ADC, and ensure their lengh to be equal. --- Quote End --- Hi Jerry, I did some more study, and I believe you can have your cake and eat it :) IMHO it can work as you describe / have drawn. Almost, as you will have to feed one FCO clock instead of one DCO clock (per group of 3 aggregated ADCs). The ALTVDS PLL requires the base clock as input. https://www.alteraforum.com/forum/attachment.php?attachmentid=13057 The FCO clocks of the three ADCs in each block will run at (exactly) the same frequency, but with an unknown phase-shift. But this phase-shift doesn't matter as the DPA circuitry in the receiver datapath will select the best phase for each data signal. It could be advantageous if you can match the trace lengths per group of 3 ADCs. The four groups can have quite different trace lengths. Also don't over-strain your self with matching the lengths between signals; 50 ps is about 7 mm trace length. Although IMHO it won't matter, the DPA will select the phase of the PLL clock to sample within 1/16 of the UI (or 62.5 ps in your case) of the ideal position. I would be careful though and also seek advice from the other Experts (FvM, Tricky, ... ?) too. Regards, Josy - Altera_Forum
--- Quote Start --- 1) I'm not a Stratix expert, so I would need to study this further, but this is outside my scope. Perhaps somebody else will answer this question? 2) The DCO clocks (and data) go to the EP2C8 devices, as the EP2SGX60 didn't have enough LVDS Receivers. From the EP2C8's I have 4 wide-parallel LVCMOS buses feeding into the EP2SGX60. 3) You still didn't tell which Stratix IV device you are targeting? Although I have to repeat I'm not a Stratix expert at all. With 12 ADC devices you will need 12 * 6 or 96 LVDS inputs in total, and 12 of them need to feed into a clock input. Achieving timing closure at 1000 Mbps, using static .sdc constraints, may turn out to be difficult. And using the DPA feature in the ALTLVDS may then be a better approach. I balanced all timing delays. On the picture the analog data is fed in from the right going left, I also fed the ADC clocks first going from the EP2SGX60 FPG to the far right and then horizontally feeding 4 ADCs. As such all analog signals are sampled at the same moment. The digital signals all reach their respective EP2C8 at the same time, but this is not essential as they are source synchronous signals. Regards, Josy --- Quote End --- Hi Josy, 1. My FPGA part is EP4SGX230KF40C4. 2. If i use ALTLVDS megafunction, my fpga doesn't support 12 ALTLVDS modules. There are toal 4 altlvds module in EP4SGX230KF40. 3. Can the DDIO decrease the speed from 1000Mbps to 500Mbps after the ADC data come into FPGA? If this is the case, the register shift will run at 500MHz in logic. BTW, I have a thought, however, i don't know if this can be implemented. You know, i will group 3 or 4 AD9633 into a group. So can i only connect one of the group's ADCs DCO to fpga, and process them by using one ALTLVDS module as the attaced image shows. Then i can receive all 12 AD9633 by 4 altlvds modules. The key issue is if DCO connected to fpga synchronizes with other ADCs output data? If not, the logic design will lose relationship between clock and data. I can carefully route the clock trace to all ADC, and ensure their lengh to be equal. http://www.alteraforum.com/forum/attachment.php?attachmentid=13055&stc=1 - Altera_Forum
--- Quote Start --- Hello Josy, Thanks for you reply. 1. Can DCO connect to IO-clock, which doesn't locate in the same IO-bank of the normal ADC output data lvds siganls connected? 2. There are 16 ADC clocks (DCO) that need to be connected to your EP2S60, and all of these DCO are connected to EP2S60's clock-IO, am i right? 3. I have 12 ADC devices. And my FPGA have total 16 normal clock-IO, exclude transceiver ref-clock. I don't think i can connect DCO to those transceiver ref-clock pins. My ADC PN is AD9633 and i want it run at 100M@10-bits, so the DCO output clock speed will be 500MHz. BTW, When you place and route your ADC channels, did you make trace length equal constrain among all DCO signals and among all ADC output lvds signals? Is this trace length equal control necessary? --- Quote End --- 1) I'm not a Stratix expert, so I would need to study this further, but this is outside my scope. Perhaps somebody else will answer this question? 2) The DCO clocks (and data) go to the EP2C8 devices, as the EP2SGX60 didn't have enough LVDS Receivers. From the EP2C8's I have 4 wide-parallel LVCMOS buses feeding into the EP2SGX60. 3) You still didn't tell which Stratix IV device you are targeting? Although I have to repeat I'm not a Stratix expert at all. With 12 ADC devices you will need 12 * 6 or 96 LVDS inputs in total, and 12 of them need to feed into a clock input. Achieving timing closure at 1000 Mbps, using static .sdc constraints, may turn out to be difficult. And using the DPA feature in the ALTLVDS may then be a better approach. I balanced all timing delays. On the picture the analog data is fed in from the right going left, I also fed the ADC clocks first going from the EP2SGX60 FPG to the far right and then horizontally feeding 4 ADCs. As such all analog signals are sampled at the same moment. The digital signals all reach their respective EP2C8 at the same time, but this is not essential as they are source synchronous signals. Regards, Josy - Altera_Forum
--- Quote Start --- Jerry, 1. The DCO LVDS signal is the high-speed output clock from the ADC. In Cyclone devices the easiest way is to use them as the IO-clock. I extrapolate this would also come easy in Stratix devices. The other way may be to use an internally PLL-generated clock and dynamically set the delay in the input cells to align the data with this clock. I haven't tried this as in Cyclone this definitely is not possible, but I think this could work in Stratix devices. 2. At the time I fed 4 octal 12-bit ADCs into an EP2C8F256. I had 4 of these feeding further into an EP2SGX60 (making 16 ADCs or 128 analog channels in total). This is the only time I used Stratix FPGA's. http://www.alteraforum.com/forum/attachment.php?attachmentid=13050&stc=1 I used the DCO of each ADC to clock in the data, and connected each DCO to a (regional) clock input. 3. How many ADC devices do you want to connect to which Stratix IV GX device? Regards, Josy --- Quote End --- Hello Josy, Thanks for you reply. 1. Can DCO connect to IO-clock, which doesn't locate in the same IO-bank of the normal ADC output data lvds siganls connected? 2. There are 16 ADC clocks (DCO) that need to be connected to your EP2S60, and all of these DCO are connected to EP2S60's clock-IO, am i right? 3. I have 12 ADC devices. And my FPGA have total 16 normal clock-IO, exclude transceiver ref-clock. I don't think i can connect DCO to those transceiver ref-clock pins. My ADC PN is AD9633 and i want it run at 100M@10-bits, so the DCO output clock speed will be 500MHz. BTW, When you place and route your ADC channels, did you make trace length equal constrain among all DCO signals and among all ADC output lvds signals? Is this trace length equal control necessary? - Altera_Forum
--- Quote Start --- 1. Must DCO be connected to clock input? 2. Does your FPGA has 8 pair LVDS clock input pins? What's your fpga PN? For you said, you have processed several octal channels ADCs, in single FPGA? 3. My fpga only has 4 pairs dedicated LVDS clocks, which on left and right sides of the FPGA. Can i connect dco to dedicated clock input pins on top or bottom sides of the FPGA? And configure them as LVDS input. The PLL_[L1,L4,R1,R4]_CLK* are the LVDS module dedicated clock, which will feed to the dedicated PLL. Also, this FPGA has many other normal clock input pins, as below figure shows. My question is that can i connect the ADC DCO signals to these clock input pins regardless of where they are (top or bottom or left or right sides)? --- Quote End --- Jerry, 1. The DCO LVDS signal is the high-speed output clock from the ADC. In Cyclone devices the easiest way is to use them as the IO-clock. I extrapolate this would also come easy in Stratix devices. The other way may be to use an internally PLL-generated clock and dynamically set the delay in the input cells to align the data with this clock. I haven't tried this as in Cyclone this definitely is not possible, but I think this could work in Stratix devices. 2. At the time I fed 4 octal 12-bit ADCs into an EP2C8F256. I had 4 of these feeding further into an EP2SGX60 (making 16 ADCs or 128 analog channels in total). This is the only time I used Stratix FPGA's. https://www.alteraforum.com/forum/attachment.php?attachmentid=13050 I used the DCO of each ADC to clock in the data, and connected each DCO to a (regional) clock input. 3. How many ADC devices do you want to connect to which Stratix IV GX device? Regards, Josy - Altera_Forum
--- Quote Start --- Jerry, you connect the DCO signals to LVDS clock input pins on the FPGA. --- Quote End --- 1. Must DCO be connected to clock input? 2. Does your FPGA has 8 pair LVDS clock input pins? What's your fpga PN? For you said, you have processed several octal channels ADCs, in single FPGA? 3. My fpga only has 4 pairs dedicated LVDS clocks, which on left and right sides of the FPGA. Can i connect dco to dedicated clock input pins on top or bottom sides of the FPGA? And configure them as LVDS input. http://www.alteraforum.com/forum/attachment.php?attachmentid=13048&stc=1 The PLL_[L1,L4,R1,R4]_CLK* are the LVDS module dedicated clock, which will feed to the dedicated PLL. Also, this FPGA has many other normal clock input pins, as below figure shows. My question is that can i connect the ADC DCO signals to these clock input pins regardless of where they are (top or bottom or left or right sides)? http://www.alteraforum.com/forum/attachment.php?attachmentid=13049&stc=1 - Altera_Forum
Jerry,
