15 years agousing lvds
G´day !! I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This seri...
9 years ago --- Quote Start --- Hello Josy, Thanks for you reply. 1. Can DCO connect to IO-clock, which doesn't locate in the same IO-bank of the normal ADC output data lvds siganls connected? 2. There are 16 ADC clocks (DCO) that need to be connected to your EP2S60, and all of these DCO are connected to EP2S60's clock-IO, am i right? 3. I have 12 ADC devices. And my FPGA have total 16 normal clock-IO, exclude transceiver ref-clock. I don't think i can connect DCO to those transceiver ref-clock pins. My ADC PN is AD9633 and i want it run at 100M@10-bits, so the DCO output clock speed will be 500MHz. BTW, When you place and route your ADC channels, did you make trace length equal constrain among all DCO signals and among all ADC output lvds signals? Is this trace length equal control necessary? --- Quote End --- 1) I'm not a Stratix expert, so I would need to study this further, but this is outside my scope. Perhaps somebody else will answer this question? 2) The DCO clocks (and data) go to the EP2C8 devices, as the EP2SGX60 didn't have enough LVDS Receivers. From the EP2C8's I have 4 wide-parallel LVCMOS buses feeding into the EP2SGX60. 3) You still didn't tell which Stratix IV device you are targeting? Although I have to repeat I'm not a Stratix expert at all. With 12 ADC devices you will need 12 * 6 or 96 LVDS inputs in total, and 12 of them need to feed into a clock input. Achieving timing closure at 1000 Mbps, using static .sdc constraints, may turn out to be difficult. And using the DPA feature in the ALTLVDS may then be a better approach. I balanced all timing delays. On the picture the analog data is fed in from the right going left, I also fed the ADC clocks first going from the EP2SGX60 FPG to the far right and then horizontally feeding 4 ADCs. As such all analog signals are sampled at the same moment. The digital signals all reach their respective EP2C8 at the same time, but this is not essential as they are source synchronous signals. Regards, Josy
