9 years ago
Timing for MAX 10 ADC Control Core Only interace logic
I'm trying to create the necessary external logic to control a MAX10 ADC Control Core Only instance. The timing in figure 8 of the UG-M10ADC User Guide does not define the relationship between command_valid, command_startpacket, command_endofpacket, or command_ready. Also, what is the reference for the term "ADC soft IP clock"? Is this the same thing as "modular_adc_pll_clock"?
    Thanks, for the code. I am having the same problem. The documentation could always be better. I will post wiring and timing diagrams when I get mine working. Currently the ADC output is all zero's.
    --- Quote Start ---
    Hi, Attached is a vhdl file that I got working.
    --- Quote End ---
    I need to post an update to this! The code I posted above works in simulation (once you get past simulation tools problems), but does NOT work in hardware. Issue: The ADC does not work if the two input clocks into the ADC are the same clock! Solution: use a different clock, or just invert the clock_clk clock.
    Hi, (note following update post about clocks) Attached is a vhdl file that I got working. I cut it down a bit, so can't guarentee it'll compile first time, but the gist is there. Is reads 2 channels periodically, using the raw version of the ADC. ADC and PLL generated using Quartus 16/17 Tools->IP Catalog. PLL converts 8MHz to 2MHz, and is there only because the ADC won't work without the PLL. The BIG problem I had was what an Altera FAE has confirmed to me is a bug in Quartus: the IP core Wizard for the ADC generates 2 sets of files: a simulation folder and a synthesis folder. Only the SYNTHESIS ADC folder contains the IP Core customisations you specified - the simulation folder just contains a blank ADC template, which naturally does not simulate. Currently I'm compiling the synthesis files manually in ModelSim, but a simpler way would likely be to just copy the synthesis files into the simulation folder. Hope this helps, Rob
    I'm running into the same problem and I would love to find someone who has a VHDL file that correctly instantiates the Max 10 ADC. I would also like to have some sharp words with whoever thought it was a good idea to make it a Qsys only component.
    I have a Max 10 ADC watching 9 analog signals - 4 power supplies and 5 actuator FET monitors. The logic is dead simple - really just a set of digital comparators with hysteresis. What I want from the ADC is set of 9 12-bit values and an update signal to tell the downstream logic a new sample set is ready.
    Even a simple example of how to instantiate and drive this thing in VHDL would be great, as I have tried everything I can think of. Quartus knows it is supposed to be there too, as it shows up in the hierarchy.
    Hi, I'm only just learning this myself, and it's taken me the best part of 3 weeks to get it simulating, so take my input with caution.
    1) I think the two clocks can be separate. The PLL clock has to come from the PLL whether you want it to or not. The other clock could be a different frequency. Say, 8MHz for the logic, and 2MHz for the PLL. I'm using the same clock for both.
    2) I don't think command_startpacket, command_endofpacket are relevant for the Core Only ADC, or at least I've not found a use yet. I have them tied low.
    3) command_valid seems to be the important signal. It seems that when you take it high and HOLD it high, some time later command_ready pulses high for one clock. (I assume this is the IP clock). Thereafter command_ready and response_valid pulse high both pulse high together for one clock, at the rate you selected when you created the IP core. response_channel() and response_data() are both valid for one clock at the same time as response_valid.
    4) It appears you can change command_channel on the fly.
