9 years agoTiming for MAX 10 ADC Control Core Only interace logic
I'm trying to create the necessary external logic to control a MAX10 ADC Control Core Only instance. The timing in figure 8 of the UG-M10ADC User Guide does not define the relationship between comma...
9 years agoI'm running into the same problem and I would love to find someone who has a VHDL file that correctly instantiates the Max 10 ADC. I would also like to have some sharp words with whoever thought it was a good idea to make it a Qsys only component.
I have a Max 10 ADC watching 9 analog signals - 4 power supplies and 5 actuator FET monitors. The logic is dead simple - really just a set of digital comparators with hysteresis. What I want from the ADC is set of 9 12-bit values and an update signal to tell the downstream logic a new sample set is ready. Even a simple example of how to instantiate and drive this thing in VHDL would be great, as I have tried everything I can think of. Quartus knows it is supposed to be there too, as it shows up in the hierarchy.
