Timing Behavior of Remote Update IP After Reset on Cyclone 10 GX (10CX150YF672E5G)
Hello Sumanth,
I am sorry we only have devkits to try.
10CX105YF672I5G - working
10CX150YF672E5G - not working
The only difference is
operating temperature Industry grade (-40'C to 100'C) is working
operating temperature Enhance grade (0'C to 100'C) is not working
From your statement, if you waited approximately 300 µs after busy deassertion, reads and writes work correctly.
So, it is not the IP is not working at all. It will be working correctly if you give some buffer around 300us after busy signal deasserts.
Is this correct?
If you give 300us buffer after busy signal deasserts, will it impact your design implementation?
regards,
Farabi
Hello Fabri,
Yes, adding ~300 µs delay after the busy signal deassertion does not cause any problem to my project from a functionality or performance perspective.
However, our main concern is understanding the actual root cause of this behavior. Specifically, we are trying to determine why there is a difference between the two part numbers (10CX105YF672I5G – industrial grade working vs. 10CX150YF672E5G – enhanced grade requiring delay), even though the functionality should ideally be consistent.
At this point, we cannot rely on a fixed or “magic number” like 300 µs without a clear technical justification. For a robust design, we need proper guidance on:
What is internally causing this delay requirement
Whether this behavior is documented or expected for certain variants
If there is a recommended way (e.g., status check or handshake) to safely determine readiness instead of using a fixed delay
Could you please provide proper direction or clarification on this?
Sumanth S
- Sumanth3 months ago
Hi Fabri,
Any update on this thread?
Sumanth S - Farabi_Altera3 months ago
Hello Sumanth,
I have discussed this with internal team, but we can't make conclusion why the other device require 300us delay to make RSU works.
Question : Do you see only 1 unit behaving like this ?
regards,
Farabi
Hi Farabi,
I searched for an alternate unit with the same part number, but currently I could not find any additional unit available for comparison/testing.
At the moment, we are observing this behavior only on this single unit.
Is there any possibility to perform further testing or analysis from your end to help identify why this device requires the 300us delay for RSU to work?
Thank you.
Sumanth S
- Farabi_Altera2 months ago
Hello Sumanth,
I can make below conclusion:
10CX105YF672I5G – industrial grade RSU working as normal
10CX150YF672E5G – enhanced grade required 300us delay to make RSU working
The only difference between -I and -E is the package temperature support. No difference in the silicon.
You are using same design, same hardware setup, same bitstream image.
You only see the delay at 1 unit. This is very difficult to make conclusion.
Next step:
1- Are you able to swap the unit with known working board?
2- Are you open to send the unit for FA?
regards,
Farabi
