Timing Behavior of Remote Update IP After Reset on Cyclone 10 GX (10CX150YF672E5G)
In the official Remote Update IP design example, the reset command waits for 0.6 seconds and then performs the read or write operations. Between each read or write operation, it waits for 0.6 seconds before proceeding with further read or write operations.
Note: The official Remote Update IP functions correctly on both boards (10CX150YF672E5G and 10CX105YF672I5G).
In my design, I wait for the busy signal to deassert before performing any further read or write operations.
- FakhrulA_altera8 months ago
Hi Sumanth,
Thanks for confirming. Since the example works on both devices, the IP is consistent. The difference I'm assuming seems related to timing in your design.
Could you please try adding a short delay after reset or between operations and see if it helps.
Let me know the result.
Fakhrul
