MartinMaa
11 months agoThe Verilog code was not actually programmed into the FPGA.
I have a question. I am using a 10M02SCM153C8G FPGA. I wrote a simple program, successfully programmed it onto the development board, and confirmed it produced the intended simple functionality. Howe...
MartinMaa
11 months agoHi Frank,
I have another question for you. I need to know how many embedded M9K memory blocks are available in the 10M02SCM153C8G FPGA.
I plan to use this FPGA to implement an 8K x 9 SYNCFIFO using an IP core. However, I have been unable to locate this specific information. I've consulted an AI, which provided conflicting responses on whether this implementation is feasible.
Could you please let me know in which chapter of the documentation I can find the data on the number of M9K memory blocks? Alternatively, would you be able to confirm if the device has sufficient resources for my application?
Thank you.
