16 years agoterminal(input or output) adding
Hi
there is two circuit with one input and one output. How can I connect the output of the first circuit to the input of the other circuit without line(wire)? (it is available in the logic emulator programs connecting two circuit without line(wire) using terminals) Best regards7 Replies
using block diagrams,and WITHOUT using wires, you can't.
thanks for reply.
How can I assign the output of "output pin" to the input of "the input pin"? or Is there a method this? best regards - Altera_Forum
| block 1 output |------>wire_name
| | |____________________| wire_name------>|input block 2 | | | |____________ ________| the two blocks do not need o be directly connect. but altera specifies that in BDF same input and output names are not connected, and you need to connect them manually. - Altera_Forum
----the input or output of the block(without wire)
Thank you very much for the solution
the problem is solved. Can I assign the wire name to the input or output of the block? or the alternative method Best regards - Altera_Forum
wires with the same name are connected (outside the SOPC block).
without using a BDF, you could use instantiations in verilog.
