16 years agoterminal(input or output) adding
Hi there is two circuit with one input and one output. How can I connect the output of the first circuit to the input of the other circuit without line(wire)? (it is available in the logic emu...
16 years ago| block 1 output |------>wire_name
| | |____________________| wire_name------>|input block 2 | | | |____________ ________| the two blocks do not need o be directly connect. but altera specifies that in BDF same input and output names are not connected, and you need to connect them manually.
