16 years agoterminal(input or output) adding
Hi there is two circuit with one input and one output. How can I connect the output of the first circuit to the input of the other circuit without line(wire)? (it is available in the logic emu...
16 years agowires with the same name are connected (outside the SOPC block).
without using a BDF, you could use instantiations in verilog.
