16 years agoterminal(input or output) adding
Hi there is two circuit with one input and one output. How can I connect the output of the first circuit to the input of the other circuit without line(wire)? (it is available in the logic emu...
16 years agoThank you very much for the solution
the problem is solved. Can I assign the wire name to the input or output of the block? or the alternative method Best regards
