17 years agoSome glitches in the simualtion waveforms
Hi, Experts,
I met a problem in my VHDL code. My algorithm is to cut in the deadtime in the incoming PWM signals and output them. I have 6 incoming PWM signals to switch 6 IGBTs. So, these 6 pwm signals are divided into three pairs: top1 & bot1, top2&bot2 and top3&bot3. I did some simulation for "top1&bot1" (deadtime_1.vhd) and "top2&bot2"(deadtime_2.vhd) pwm signals. But, the result is weird: when I only use top1&bot1, the simulation result is good; when I use both "top1&bot1" and "top2&bot2", there are some glitches in waveforms in the simulation....It looks like the clocks are fighting with each other periodically after some cycles. I attached my vhdl code and simulation results. Please give me some advices... GREATLY APPREICATE YOUR HELP!!!!!
