17 years agoSome glitches in the simualtion waveforms
Hi, Experts, I met a problem in my VHDL code. My algorithm is to cut in the deadtime in the incoming PWM signals and output them. I have 6 incoming PWM signals to switch 6 IGBTs. So, these 6 p...
17 years agoBased on what you recommended, I re-wrote the code with a regular edge sensitive design structure. However, the result is the same. Maybe there is something other than the structure causes the problem...
Still debugging it.....
