Simulation script for project with multiple IPs
I am trying to simulate a project that has one instance of On-chip flash memory, multiple instances of Soft LVDS IP core and one instance of ALTPLL IP. When I try to simulate it gives this error:
"# ** Error: (vlog-7) Failed to open design unit file "C:/Users/Sarmad/Documents/Altera/TRR_Main_Digital_module_v1.1/LVDS_Channel_1_Tx.vo" in read mode.
# No such file or directory. (errno = ENOENT)"
It seems there is some issue with the simulation script. Is there a tutorial or guideline that details how to write or amend the simulation script in case of multiple IPs. Thanks
Sarmad
- RichardT_altera
Do you able to solve the issue? Do you need further help?
- SMS
No, the issue remains unresolved. Yes definitely.
- tessellation
I had this or a similar problem trying to simulate IP cores with a Quartus Lite project in ModelSim. I am used to using Quartus Pro where you just generate a simulator setup script using that function under tools. However, that is not available with Quartus lite.
So there are base IP cores like counters, fifo and rom that don't create a .tcl file when they are generated. For these you just need to add a vcom for them in your .tcl or .do file.
For IP cores like fft and fir they do generate a .tcl file. Look in their simulation -> mentor folder and you will find it. Copy that .tcl and the whole simulator folder to you main project directory. With the .tcl in your main directory uncomment/fill in the appropriate lines, including vcom of the base IP cores.
Then you can just source <your tcl file>.tcl in model sim.
Hope this helps someone out there.
- SMS
I am using Max10 (to be exact 10M16SAE144I7G). I tried ip-make-simscript as well and it gave me the same error.
- RichardT_altera
May I know which device are you targeting? Found out that the ip-setup-simulation script was designed to work with family 10 devices and will not work properly with any other devices. As a workaround, you can use the ip-make-simscript that let you point directly to the spd files for each IP. You can find a brief description in Table 40 on the Intel® Quartus® Prime Standard Edition Handbook Volume 1 Design and Synthesis. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/archives/qts-qps-5v1-17-1.pdf#page=255 - SMS
I have also tried to setup simulation using command prompt (ip-setup-simulation) but it gives this error: "No spd files are included in quartus project", although .spd files for all the IP cores (except ALTPLL) are there in the project folder. Can anyone please suggest a solution or point me to a guide that one can follow in such a situation. Thanks
- NBRUM
vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L fiftyfivenm_ver -L work -voptargs="+acc" <module_to_simulate>
make sure that modelsim has those lib visible.
- AndyN
How did you generate your simulation script? Are you compiling each IP separately? The easiest answer is to go to Quartus Tools>Generate Simulator Setup Script for IP. This'll give you a single file to compile all of the IP in your project.
- SMS
Simulation script for each IP core was generated automatically when the IPs were added to the project. And the whole project is compiled collectively. Actually the Quartus version that I am using (Quartus Prime 18.0 Lite Edition) does not have any such option in Tools menu. I tried to do the same from "Project > Upgrade IP Components > Generate Simulator Script for IP" but that button is not enabled (greyed out).
Moreover I have also tried adding a Nativelink setup simulation script (*.do) but that also doesn't make it work.
