Simulation script for project with multiple IPs
How did you generate your simulation script? Are you compiling each IP separately? The easiest answer is to go to Quartus Tools>Generate Simulator Setup Script for IP. This'll give you a single file to compile all of the IP in your project.
- SMS7 years ago
Simulation script for each IP core was generated automatically when the IPs were added to the project. And the whole project is compiled collectively. Actually the Quartus version that I am using (Quartus Prime 18.0 Lite Edition) does not have any such option in Tools menu. I tried to do the same from "Project > Upgrade IP Components > Generate Simulator Script for IP" but that button is not enabled (greyed out).
Moreover I have also tried adding a Nativelink setup simulation script (*.do) but that also doesn't make it work.
