SMS
7 years agoSimulation script for project with multiple IPs
I am trying to simulate a project that has one instance of On-chip flash memory, multiple instances of Soft LVDS IP core and one instance of ALTPLL IP. When I try to simulate it gives this error: "#...
RichardT_altera
7 years agoMay I know which device are you targeting?
Found out that the ip-setup-simulation script was designed to work with family 10 devices and will not work properly with any other devices.
As a workaround, you can use the ip-make-simscript that let you point directly to the spd files for each IP. You can find a brief description in Table 40 on the Intel® Quartus® Prime Standard Edition Handbook Volume 1 Design and Synthesis.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/archives/qts-qps-5v1-17-1.pdf#page=255
