bhunt's avatar
bhunt
3 years ago
Simulation problem with Avalon-MM clock crossing bridge
Hi there, I'm using the avalon MM clock-crossing bridge with questasim. After generating the core in Quartus Prime, I compile it in questasim with no issues. However, in simulation, all of its output ports are stuck at X.
  • bhunt's avatar
    bhunt
    3 years ago
    I found that the IP simulation model outputs X normally, after reset, until the first transaction is passed through it. Then the IP outputs stay non-X.
  • SyafieqS's avatar
    SyafieqS
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
  • SyafieqS's avatar
    SyafieqS
    May I know if there is any update from previous reply?
  • SyafieqS's avatar
    SyafieqS
    Understood. Any testbench written for this simulation? Mind to share here if there is any.
    If there is any input value assigned to the input there should be a value outputted.
  • SyafieqS's avatar
    SyafieqS
    Are you writing any testbench? mind to share it here the snippet? and also the snapshot in the questasim.
    • bhunt's avatar
      bhunt
  • KennyT_altera's avatar
    KennyT_altera
    Kindly take note that they will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
