bhunt
3 years agoSimulation problem with Avalon-MM clock crossing bridge
Hi there,
I'm using the avalon MM clock-crossing bridge with questasim. After generating the core in Quartus Prime, I compile it in questasim with no issues. However, in simulation, all of its output...
- 3 years ago
I found that the IP simulation model outputs X normally, after reset, until the first transaction is passed through it. Then the IP outputs stay non-X.
SyafieqS
3 years agoAre you writing any testbench? mind to share it here the snippet? and also the snapshot in the questasim.
- bhunt3 years ago
