bhunt
3 years agoSimulation problem with Avalon-MM clock crossing bridge
Hi there,
I'm using the avalon MM clock-crossing bridge with questasim. After generating the core in Quartus Prime, I compile it in questasim with no issues. However, in simulation, all of its output...
- 3 years ago
I found that the IP simulation model outputs X normally, after reset, until the first transaction is passed through it. Then the IP outputs stay non-X.
KennyT_altera
3 years agoKindly take note that they will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
