bhunt
3 years agoSimulation problem with Avalon-MM clock crossing bridge
Hi there,
I'm using the avalon MM clock-crossing bridge with questasim. After generating the core in Quartus Prime, I compile it in questasim with no issues. However, in simulation, all of its output...
- 3 years ago
I found that the IP simulation model outputs X normally, after reset, until the first transaction is passed through it. Then the IP outputs stay non-X.
SyafieqS
3 years agoAs we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
