bhunt
3 years agoSimulation problem with Avalon-MM clock crossing bridge
Hi there,
I'm using the avalon MM clock-crossing bridge with questasim. After generating the core in Quartus Prime, I compile it in questasim with no issues. However, in simulation, all of its output...
- 3 years ago
I found that the IP simulation model outputs X normally, after reset, until the first transaction is passed through it. Then the IP outputs stay non-X.
SyafieqS
3 years agoUnderstood. Any testbench written for this simulation? Mind to share here if there is any.
If there is any input value assigned to the input there should be a value outputted.
