14 years ago
Simulation Problem Multiplier 8 bits
Here is the code:
Library ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity Multiplier8 is port (clk : in std_logic;
done : out std_logic ;
reset : in std_logic ;
Multiplier : in std_logic_vector(7 downto 0);
Multiplicand : in std_logic_vector(7 downto 0);
Product : out std_logic_vector(15 downto 0);
start : in std_logic ) ;
end Multiplier8;
architecture behavior of Multiplier8 is
type state_type is (s0, s1, s2);
signal state : state_type ;
signal A,B,Q : std_logic_vector (7 downto 0);
signal ab : std_logic_vector (8 downto 0);
signal p : std_logic_vector (3 downto 0);
signal Product1,Product2 : std_logic_vector (16 downto 0);
begin
process(clk,reset)
begin
if reset='1' then state<=s0;
elsif clk'event and clk='1' then
case state is
when s0=> if start='1' then state<=s1; p<="1000"; else state<=s0; end if;
when s1=> p<=p-1; state<=s2;
when s2=> if p="0000" then state<=s0; done<='1'; else state<=s1; end if;
end case;
end if;
end process;
process(state)
begin
case state is
when s0=> A<="00000000"; Q<=Multiplier; B<=Multiplicand;
when s1=> if Q(0)='1' then ab<=('0' & A) + ('0' & B ); end if;
when s2=> Product1<= (ab & Q); Product2<= '0' & Product1(16 downto 1); Product<=Product2(15 downto 0);
end case;
end process;
end behavior;
But when i start the simulation the are nodes problems. The program is for a 8 bit Multiplier with shift.
    The problem is the latches in the 2nd process. To prevent latch creation in an asynchronous process, every output needs to be assigned in EVERY branch. You are also missing signals from the sensitivity list.
    I used modelsim and changed this part:
    when s1=> if Q(0)='1' then ab<=('0' & A) + ('0' & B ); else ab<=('0' & a); end if;
    It still does not work. I take no result. It goes to the right states and when counter reaches 0 i get done=1 but no result. Any ideas?
    Apart from known weaknesses of Max plus II VHDL handling, it's complaints about the shown code seem reasonable.
    It's storing several intermediate results in combinational latches. It's questionable if they will consistent.
    I suggest coming a little more up to date and using modelsim.
    Max plus 2 is over 10 years old and pretty crap.
    Find nil-period oscillation
    Continue simulating with these inputs,or cancel simulation.
    That's the message i receive.
