FakhrulA_altera
5 days agoHi Sameer,
Apologies for the delayed response.
Could you please refer to the following KDB articles for this specific CONF_DONE error?
- https://community.altera.com/kb/knowledge-base/why-do-i-receive-the-error-conf-done-pin-failed-to-go-high-in-device-x-when-i-tr/347292
- https://community.altera.com/kb/knowledge-base/error-conf-done-pin-failed-to-go-high-in-device-/340233
Please also try programming with the attached .sof file and confirm whether the same error is observed.
For the next step, could you please try the following?
- Keep all DIP switches at the factory default setting.
- Remove any external connection or daughter card from the board.
- Power cycle the board.
- Program only the official example .sof file from the Cyclone V E Development Kit design package.
- If probing is available, please check the CONF_DONE, nSTATUS, and nCONFIG signal levels during programming.
Also, could you confirm how many Cyclone V E development kit boards show this same behavior out of the total boards tested?
Fakhrul
- Sameer-sahu1 day ago
Hi FakhrulA_altera ,
I will try this and let you know.
