Cyclone IV drop in replacement confirmations
Hi Brian,
reading Cyclone IV datasheet strictly, Table 1-15 has also to be observed. It specifies Vinh,max of 2.25 V for 1.8 V banks. Don't no why and how the spec is related to general 3.6 Vin,max in table 1-3 and 1-4. According to device handbook, PCI diode isn't used vor 1.8 V and below I/O standards.
Regards Frank
FvM
Well if you read from top to bottom:
The table for output uses VCCIO and input Max=3.6V ~ha!
If your statement holds, then the output should be a fixed number as well for generalized numbers.
My question is not about GPIO use cases, you might argue but ticket is about drop in replacement not standard signal goes high / low with current-limited driver.
I will prefer Altera staffs to handle my ticket.
Thank you
- FvM15 days ago
Hi Brian,
I apologize for not reading your question thoroughly. I didn't realize that you asked about feeding 2.5 VCCA supply to a 1.8 V GPIO due to migration compatible pin assignment. That should always work. To be sure, you can check the respective assignment in Quartus pinout table.
I checked that Quartus indicates connection of VCCA4 (PIN_L12) to 2.5 V for EP4CE10F17 if you select migration compatibility to CE22, no matter that's in a 1.8 V bank.
Regards Frank
- BrianSune_Froum15 days ago
Contributor
Dear Sir,
Stop it. Please stop your replies with all do respect.
You referred information from the datasheet and corrects me in previous reply and said the input for VCCIO is subjected to the table from 1.8Vccio aka 2.25 Vmax not the front table VIN max.
Stop your replies and free Altera to response.
For community help and more clear message stop your madness immediate!
Deep appreciation!!!
Brian
