15 years agoQuestion about Monitor
is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?117 Replies
Hi Aditya,
--- Quote Start --- ... These systems have no bus ... I am not using any Bus [such as PCIe/ixp bus] and the connection is through the Avalon switch fabric. --- Quote End --- The Avalon switched fabric is a bus protocol. The Altera Verification IP Suite contains BFMs for testing the protocol(s). --- Quote Start --- ... when I include the bus [I am using a simple expansion bus [ixp]] ... --- Quote End --- What is IXP? Is it the old ARM XScale bus? --- Quote Start --- ... when I connect the master of the bus to the slave of the RAM ... --- Quote End --- If you have an external processor connected to an Avalon fabric, then the interface should be an IXP-to-Avalon bridge. If the external bus can only be owned by the processor, then the bridge will only have an Avalon-MM master interface on the Avalon side. If however the external bus can be arbitrated for by the processor or the FPGA, then the Avalon interface can have both master and slave interfaces. --- Quote Start --- ... here are the difficulties I face ... --- Quote End --- The Altera Verification IP suite Avalon BFMs are for testing Avalon components. For an IXP-to-Avalon bridge design, you would require both Avalon BFMs and IXP BFMs, and monitors for those buses. The testbench for your bridge design would contain your bridge component, the bus monitors, and the BFMs. Your test case generator would throw lots of transactions at the design in an attempt to test every path through your bridge code (code coverage would tell you what is missed). Illegal activity would trigger assertion violations. Your tests would include transactions where both the IXP master and an Avalon-MM master issued transactions to the RAM and checked the results. This would result in simultaneous accesses that would be arbitrated by the slave-side arbitration inside the FPGA. --- Quote Start --- I have tried to explain things as clearly as possible, If I still haven't explained the problem clearly, I will explain it one more time with some screen shots. --- Quote End --- I think I have understood what you are trying to do, but a block diagram would help clarify. Cheers, Dave - Altera_Forum
Hello Dave,
Thank you for your quick response Dave. Yes, I have written simple programs [test_program.sv] for simple systems. [These systems have no bus. I am just writing to an on-chip RAM. In the first layer/level, I only have a ram, a clock and a reset. Next I export the slave of RAM [the default name is s1]. The clock and reset are already exported by default. Then I attach clock BFM, reset BFM and Avalon Master BFM to the top level [containing ram and clock] system instance. Later I write a test program containing API's to write data, read etc....]. this works and i can see the written data in the ram.. But I am not using any Bus [such as PCIe/ixp bus] and the connection is through the Avalon switch fabric. system 2: Now, when I include the bus [I am using a simple expansion bus [ixp]] and when I connect the master of the bus to the slave of the RAM, here are the difficulties I face: a) How do I use the BFM to write data [I want to use the API's for the Avalon Master BFM given in the API manual] to the RAM [remember the master of the BUS is connected to the slave of the RAM]. Since the mater of the BUS is connected to the slave of the RAM, I cannot export the RAM's slave pin because, then the connection between the bus.master and ram.slave gets disconnected. So the only thing I can do is to drive the slave of the BUS. But when I drive the slave of the BUS using Avalon MM BFM, I can only write to the memory locations of the slave of the bus using the API's, my big question is : "how do i access the memory locations of the ram", with a bus ip between Avalon MM master BFM and the on chip RAM my questions after trying to implement system 2[above] The reason why I am trying to implement the above system is, I read in the tutorials that in order to test a system, you need to export some of the pins to which you apply the stimulus using the BFM's. questions a) Is it even possible to implement such a system [like what I am trying to do above] b) Is it necessary to test the systems only using BFM's? c) Based on what I know, if you want to test any system in Qsys you need to export the signals right? without exporting you cannot test anything right? d) Am I supposed to use APIs' only to test individual components and not the entire system? I have tried to explain things as clearly as possible, If I still haven't explained the problem clearly, I will explain it one more time with some screen shots. Thanks a lot for you time and effort, Aditya - Altera_Forum
--- Quote Start --- Monitors can be synthesized but not recommended right? --- Quote End --- You're missing the point. The task of a monitor is to confirm that components adhere to the bus protocol specification. If a component will violate the bus specification, then its likely the bus will lock-up, and your system will freeze. Sure you can have a watch-dog reset the bus, and perhaps have a 'reset reason' and a backtrace. But all this can be reproduced in the simulation much easier. You setup randomized bus transactions, and code coverage, etc., and make sure things are well tested. Then you can synthesize. --- Quote Start --- I will do some reading and get back to you about this. --- Quote End --- Sure. I'm not saying they don't exist, but the question is what use are they? Feel free to come up with a good reason :) --- Quote Start --- I have just started Qsys a few weeks ago, apart from the tutorials provided by qsys are there any other online tutorials/ good books about qsys. --- Quote End --- You will learn best by building components, constructing _hw.tcl files, and synthesizing them. The nice thing about this approach is that you can get Quartus to generate an _hw.tcl file for some simple components, and then read the documentation about the settings. Things will make much more sense then. The Quartus handbook has chapters on Qsys. I think alot of the component stuff is the same as the SOPC Builder stuff, so you can look at that manual too. The Qsys tutorial has layers of hierarchy, since Altera wants to show off the new features of Qsys relative to SOPC Builder. Rather than using that to learn from, try to create a design with an Avalon-MM BFM master, and an Avalon-MM slave registers interface; don't use the PIO core, write your own. Then write a SystemVerilog testbench to generate read/write transactions to your registers. You can add an Avalon-MM monitor into your testbench, and then generate transactions that violate the bus specification, eg. perform a read or write with invalid byte enables and see the assertion failure messages. You must have a tool that supports System Verilog Assertions (SVA), like the full version of Modelsim, otherwise you will not get the SVA messages. Cheers, Dave - Altera_Forum
Monitors can be synthesized but not recommended right?. I will do some reading and get back to you about this.
I have just started Qsys a few weeks ago, apart from the tutorials provided by qsys are there any other online tutorials/ good books about qsys. Thank you, Aditya - Altera_Forum
--- Quote Start --- I came across some papers which discussed about developing monitors in SVA [System Verilog Assertion Language] and it stated that these monitors can be synthesized. --- Quote End --- Have a look at the source code. I think you'll find it wrapped in synthesis off/on blocks so that Quartus never even sees the code. That's certainly the case for the Avalon-MM master BFM component. The complication regarding synthesized assertions, is that an assertion needs some method of reporting failures, so a synthesizeable assertion checker would need an Avalon-MM interface with a block of control/status registers so that you could check for assertion failures, and clear error counters. But if your transaction just locked up the Avalon-MM bus, how would you read that register? You really don't want your transactions to fail in real hardware. That is what verification testing is for in the simulator :) Cheers, Dave - Altera_Forum
Thanks Dave. I came across some papers which discussed about developing monitors in SVA [System Verilog Assertion Language] and it stated that these monitors can be synthesized.
"This paper presents one implementation of the Open Control Protocol (OCP) monitoring on the synthesized FPGA design using the implemented library of Synthesizable SystemVerilog Assertions (SSVA). The SSVA library is developed using the layer structure of SystemVerilog assertions. It is used in implementation of the monitors for two profiles of the OCP. SSVA library and OCP monitors are then functionally verified in simulator using the test case of the processor-memory communication. The test case is then synthesized on CHIPit Platinum Edition FPGA. The implemented library and monitors can be used in many commercial and educational projects due to their simplicity and low FPGA area usage." - Altera_Forum
--- Quote Start --- is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"? --- Quote End --- No. The monitors are there to generate assertion messages regarding Avalon-MM bus protocol violations. Cheers, Dave
