15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- I came across some papers which discussed about developing monitors in SVA [System Verilog Assertion Language] and it stated that these monitors can be synthesized. --- Quote End --- Have a look at the source code. I think you'll find it wrapped in synthesis off/on blocks so that Quartus never even sees the code. That's certainly the case for the Avalon-MM master BFM component. The complication regarding synthesized assertions, is that an assertion needs some method of reporting failures, so a synthesizeable assertion checker would need an Avalon-MM interface with a block of control/status registers so that you could check for assertion failures, and clear error counters. But if your transaction just locked up the Avalon-MM bus, how would you read that register? You really don't want your transactions to fail in real hardware. That is what verification testing is for in the simulator :) Cheers, Dave
