15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoThanks Dave. I came across some papers which discussed about developing monitors in SVA [System Verilog Assertion Language] and it stated that these monitors can be synthesized.
"This paper presents one implementation of the Open Control Protocol (OCP) monitoring on the synthesized FPGA design using the implemented library of Synthesizable SystemVerilog Assertions (SSVA). The SSVA library is developed using the layer structure of SystemVerilog assertions. It is used in implementation of the monitors for two profiles of the OCP. SSVA library and OCP monitors are then functionally verified in simulator using the test case of the processor-memory communication. The test case is then synthesized on CHIPit Platinum Edition FPGA. The implemented library and monitors can be used in many commercial and educational projects due to their simplicity and low FPGA area usage."
