8 years agoQuartus Prime Lite - Difficulties with simulation
Hi all,
I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PLL generated through the wizard, and watch the clock and locked outputs. As you can see from the simulation the lock remains low, and the clock output is in an unknown state. I don't see any warnings or errors in modelsim. Any help would be greatly appreciated.
library ieee;
use ieee.std_logic_1164.all;
entity top is
port
inclk0 : in std_logic;
c0 : out std_logic;
locked : out std_logic
end entity;
architecture rtl of top is
component pll0
PORT
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
end component;
begin
pll0_inst : pll0 PORT MAP (
inclk0 => inclk0,
c0 => c0,
locked => locked
end rtl;
https://alteraforum.com/forum/attachment.php?attachmentid=14807&stc=117 Replies
When you generated the ALTPLL core, did you use the reset pin and what is the setting for the reset ( PLLs can be reset internally or via external reset pin). If you have used reset internally, the reset logic will be added internally and PLL will auto-reset itself on Power-on. If using external reset , you will have to provide the reset controls as you've already done. During simulations, have you also included the device specific simulation libraries for the PLLs? - Abr - Altera_Forum
I have tried the PLL with and without the "Enable self-reset on loss lock" check. No difference. I tried adding a pfdena input tied to 1'b1 and !ResetN - no difference.
What seems most strange to me is that the simulation shows the c0 output in the HiZ state. I don't understand what's in that block, but I would not expect it to be HiZ ever. I will submit a support case and see if I can send the testpll folder for you to look at. Service request# 11384121 This is the output I get from modelsim: # Reading C:/intelFPGA_lite/17.1/modelsim_ase/tcl/vsim/pref.tcl# do testpll_run_msim_rtl_verilog.do# if {[file exists rtl_work]} {# vdel -lib rtl_work -all# }# vlib rtl_work# vmap work rtl_work# Model Technology ModelSim - Intel FPGA Edition vmap 10.5b Lib Mapping Utility 2016.10 Oct 5 2016# vmap work rtl_work # Copying C:/intelFPGA_lite/17.1/modelsim_ase/win32aloem/../modelsim.ini to modelsim.ini# Modifying modelsim.ini# # vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source/testpll_20180302.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source/testpll_20180302.v # -- Compiling module testpll# # Top level modules:# testpll# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL/testpll_altpll.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL/testpll_altpll.v # -- Compiling module testpll_altpll# # Top level modules:# testpll_altpll# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db/testpll_altpll_altpll.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db/testpll_altpll_altpll.v # -- Compiling module testpll_altpll_altpll# # Top level modules:# testpll_altpll_altpll# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# # vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source/TB_1_20180301.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source/TB_1_20180301.v # -- Compiling module TB_1# # Top level modules:# TB_1# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# # vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclone10lp_ver -L rtl_work -L work -voptargs="+acc" TB_1# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclone10lp_ver -L rtl_work -L work -voptargs=""+acc"" TB_1 # Start time: 10:25:41 on Mar 02,2018# Loading work.TB_1# Loading work.testpll# Loading work.testpll_altpll# Loading altera_mf_ver.altpll# Loading altera_mf_ver.ALTERA_DEVICE_FAMILIES# Loading altera_mf_ver.pll_iobuf# # add wave *# view structure# .main_pane.structure.interior.cs.body.struct# view signals# .main_pane.objects.interior.cs.body.tree# run -all# 0 << Starting Simulation >> # 5651<< Simulation Complete >> restart -f add wave -position end sim:/TB_1/testpll/testPLL/areset add wave -position end sim:/TB_1/testpll/testPLL/pfdena add wave -position end sim:/TB_1/testpll/testPLL/inclk0 add wave -position end sim:/TB_1/testpll/testPLL/locked add wave -position end sim:/TB_1/testpll/testPLL/c0 run -all# 0 << Starting Simulation >> # 5651<< Simulation Complete >> https://alteraforum.com/forum/attachment.php?attachmentid=14913&stc=1 Hopefully this is something simple I've overlooked. If so, I'll be sure to post exactly what it is for others to learn from. - Altera_Forum
I got the similar design logic to work on ModelSim Intel edition and Quartus 17.1 (with latest updates) . Here's the code ;
The PLL locked at the input clock, Locked port went high and the counter output was generated. I've included the QAR file, you could extract it and check it out. The device used is Cyclone 5 GX, so the PLL used is Altera_PLL. I'll be generating one more with the Cyclone10LP device and the ALTPLL function as well. - Abrmodule plltest ( Clock, Reset, Locked, CountOut ); input Clock; input Reset; output Locked; output CountOut; wire CountOut; wire Locked; reg Count; wire PLL_clock; pll_1 counter_pll ( .refclk (Clock), .rst (~Reset), .locked (Locked), .outclk_0(PLL_clock) ); always@(posedge PLL_clock or negedge Reset) begin if (~Reset) begin Count <= 4'b0000; end else begin if(Locked) begin Count <= Count + 4'b0001; end else begin Count <= 4'b0000; end end end //always assign CountOut = Count; endmodule - Altera_Forum
Just tried with the ALTPLL function and the output clock is not being generated. This is definitely a sim model issue and needs to be fixed by Altera. Thanks for pointing it out. -Abr - Altera_Forum
Thanks very much for taking the time to verify that it doesn't work! It would have been simple to have left it without trying the 10 LP and ALTPLL, and I would have spent a bunch of time fruitlessly trying to replicate your results in my environment. I'm glad to know that I'm not (completely) crazy or a (complete) moron. :)
Any suggestions for tricking a testbench into generating the PLL output clock without changing the synthesized code? I suppose I could just create a version with an input clock to the FPGA that replaces the PLL output for functional testing, but the timing would likely be totally whacked. And please advise on the estimated timeframe for the simulator fix. I know that's asking a lot. Thanks again! - Altera_Forum
--- Quote Start --- Thanks very much for taking the time to verify that it doesn't work! It would have been simple to have left it without trying the 10 LP and ALTPLL, and I would have spent a bunch of time fruitlessly trying to replicate your results in my environment. I'm glad to know that I'm not (completely) crazy or a (complete) moron. :) Any suggestions for tricking a testbench into generating the PLL output clock without changing the synthesized code? I suppose I could just create a version with an input clock to the FPGA that replaces the PLL output for functional testing, but the timing would likely be totally whacked. And please advise on the estimated timeframe for the simulator fix. I know that's asking a lot. Thanks again! --- Quote End --- Yes we acknowledged this bug/issue and has been reported to the engineering team. however you can run cyclone 10 lp altpll vhdl simulation model in quartus v17.0 and v17.1.it works fine Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
Please check the below link the problem has been addressed. https://www.altera.com/support/suppo...-lp-pll-i.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
