8 years agoQuartus Prime Lite - Difficulties with simulation
Hi all, I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PL...
8 years agoHi,
I got the similar design logic to work on ModelSim Intel edition and Quartus 17.1 (with latest updates) . Here's the code ;
module plltest (
Clock,
Reset,
Locked,
CountOut
input Clock;
input Reset;
output Locked;
output CountOut;
wire CountOut;
wire Locked;
reg Count;
wire PLL_clock;
pll_1 counter_pll (
.refclk (Clock),
.rst (~Reset),
.locked (Locked),
.outclk_0(PLL_clock)
always@(posedge PLL_clock or negedge Reset) begin
if (~Reset) begin
Count <= 4'b0000;
end
else begin
if(Locked) begin
Count <= Count + 4'b0001;
end
else begin
Count <= 4'b0000;
end
end
end //always
assign CountOut = Count;
endmodule
The PLL locked at the input clock, Locked port went high and the counter output was generated. I've included the QAR file, you could extract it and check it out. The device used is Cyclone 5 GX, so the PLL used is Altera_PLL. I'll be generating one more with the Cyclone10LP device and the ALTPLL function as well. - Abr
