14 years ago
Problem with Always block
I have an Always block that is supposed to run when variable a assigned to 1. But it actually runs anytime when synthesising in Quartus. Can anyone help me resolve it? :confused:
 module main;
       bit a = 0;
       always @ (a==1)
           begin
                 // Run code
           end
 endmodule
    Your usage of the keywords task/endtask doesn't comply with the Verilog generate syntax, I think. Try with the syntax specified in the Verilog specification.
    Can anyone help me resolve this error:
    genvar j;
    generate
      task gen;
        for (j=1; j<=10; j++)
          begin
          end
      endtask
    endgenerate
    Error : value must not be assigned to nonvariable "j"
    Look you should keep in mind that a hardware is static and concurrent.
    You cant instantiate a logic dependent on a variable signal, that not the correct way. Think over your logic , learn about generate block.
    Good luck
    I am wondering if there is a way to intentionally send a signal to execute a logic when we need rather than using a clock signal. :rolleyes:
    There's a simple answer to this post.
    sensitivity lists in always blocks except posedge or negedge are ignored in synthesis.
    Sensitivity lists matters in smulation, synthesis results are identical to always @ *
    Why is it so? Level sensitive always blocks are describing combinational logic. The synthesized logic equations are combinations of input terms, they are assigned unconditionally, not depending on any events.
    Functional simulation is working different, interpreting the code line by line. Sensitivity lists are used to save simulation time, evaluating only the part of the code that is expected to have changed output.
    Yes it will offcourse, i did mention it in my previous post.
    Look "a" has to be some parameter or a static signal.
    You cannot control synthesis of a logic based on a variable which is either in the portlist or defined as a signal.
    Now if you have "a" as a parameter then you can do something like this
    parameter a = 1'b1
    generate
    if (a==1'b1) begin
    always @ *
    begin
    //code
    end
    end
    but i dont think if a is a signal then you can control synthesis of the code.
    I changed the always block, but it always run the code inside whatever the variable a is. :p
    always @*
    begin
    if (a==1'b1)
    //code
    end
    First of all i cant comment whether this is synthesizable because generally we write always @ (signal) or always @ (posedge clk or negedge rst) we dont check any value in the sensitivity list. I personally havnt seen such a code like what you have written. Is it synthesizable ? Did the tool throw an error ?
    That being said lets assume that its synthesizable then the question arises that what kind of logic you want. If you want a combi logic and if this code is synthesizable i guess it can work..but if you want a sequential logic i guess i wont work and the tool must throw an error.
    Now again if this is synthesizable it will be synthesized irrespective of the value.
    But i guess you should change the coding style.
    Lets say you want a block of code to be executed only if a==1'b1.
    You can write like this
    always @ * for combi or always @ (posedge sys_clk or negedge rst)
    Note: if reset is synchronous then only always @ (posedge clk) for sequential logic and then give highest priority to "a" like
    always @*
    begin
    if (a==1'b1)
    //code
    end
    yes the always block will be synthesized but you will see effects in simulation. I really have no idea for always @ (a==1).
    GOOD LUCK
