14 years agoProblem with Always block
I have an Always block that is supposed to run when variable a assigned to 1. But it actually runs anytime when synthesising in Quartus. Can anyone help me resolve it? :confused:
module mai...
14 years agoFirst of all i cant comment whether this is synthesizable because generally we write always @ (signal) or always @ (posedge clk or negedge rst) we dont check any value in the sensitivity list. I personally havnt seen such a code like what you have written. Is it synthesizable ? Did the tool throw an error ?
That being said lets assume that its synthesizable then the question arises that what kind of logic you want. If you want a combi logic and if this code is synthesizable i guess it can work..but if you want a sequential logic i guess i wont work and the tool must throw an error. Now again if this is synthesizable it will be synthesized irrespective of the value. But i guess you should change the coding style. Lets say you want a block of code to be executed only if a==1'b1. You can write like this always @ * for combi or always @ (posedge sys_clk or negedge rst) Note: if reset is synchronous then only always @ (posedge clk) for sequential logic and then give highest priority to "a" like always @* begin if (a==1'b1) //code end yes the always block will be synthesized but you will see effects in simulation. I really have no idea for always @ (a==1). GOOD LUCK
