15 years agoProblem in ahdl-source
Hello all!
I want create component which holds vcc-state after than high state is on each input. Clr resets state. I supposed that is a very simple. My idea is using dffe primitive with: clk = Inp, d = vcc, clrn = not(Rst). My code for 32 inputs is below: CODE BEGIN -- Prototype function dffe --FUNCTION DFFE (D, CLK, CLRN, PRN, ENA) --RETURNS (Q); PARAMETERS ( Width = 32 ); SUBDESIGN holdmax ( clk : INPUT; -- clock Ena : INPUT; -- enable Rst : INPUT; -- reset by "1" I[Width-1..0]: INPUT; -- input data bus O[Width-1..0]: OUTPUT; -- quit ) VARIABLE tapes[Width-1..0] : NODE; BEGIN FOR k IN 0 TO (Width-1) GENERATE tapes[k] = dffe(vcc, I[k], not(Rst), vcc, Ena); END GENERATE; O[] = tapes[]; END; CODE END But I have problems with my code:( This code is compiled in Quartus 9.1 correctly. Another situation is in Max2Plus! I have warning "Ignored unnecessary INPUT pin 'Clk'" and signal Clk is not used!(?) I need code which can be compiled correctly in either program. Where is my problem? Is it my bad code? Thanks all!4 Replies
2celsung:
Ok. Thank you for help! - Altera_Forum
library ieee;
use ieee.std_logic_1164.all; entity eugen is port ( clk : in std_logic; clrn : in std_logic; o : out std_logic_vector(31 downto 0) ); end eugen; architecture eugen_RTL of eugen is begin process (clk, clrn) begin if (clrn = '0') then o <= (others => '0'); elsif rising_edge(clk) then o <= (others => '1'); end if; end process; end eugen_RTL; - Altera_Forum
2All:
I solved my problem. 2celsung: (http://www.alteraforum.com/forum/member.php?u=5333) Thank you for answer! It is a good decision for me. But I expain: Now I see that Clk signal is ignored in Quartus too. I did some mistakes when used Max2Plus:( Compiled results are equal in either software Max2Plus and Quartus. If you want you can rewrite my code. Now I use "xport.exe" utility (from Xilinx software) for conversion ahdl to verilog (or vhdl). I want to compare youre code and my verilog code which was translated by "xport" utility (If you want of cource:)) - Altera_Forum
If I were you, I would rewrite your code in VHDL or Verilog an compile it under Quartus II.
