15 years agoProblem in ahdl-source
Hello all! I want create component which holds vcc-state after than high state is on each input. Clr resets state. I supposed that is a very simple. My idea is using dffe primitive with: clk =...
15 years ago2All:
I solved my problem. 2celsung: (http://www.alteraforum.com/forum/member.php?u=5333) Thank you for answer! It is a good decision for me. But I expain: Now I see that Clk signal is ignored in Quartus too. I did some mistakes when used Max2Plus:( Compiled results are equal in either software Max2Plus and Quartus. If you want you can rewrite my code. Now I use "xport.exe" utility (from Xilinx software) for conversion ahdl to verilog (or vhdl). I want to compare youre code and my verilog code which was translated by "xport" utility (If you want of cource:))
