15 years ago
Problème programmation Pin
For the passage of a signal, I use a pin in High Impedance, I declare it with :
HZ : out std_logic_vector(11 downto 0);
HZ<="ZZZZZZZZZZZZ";
My problem is with programming many CPLD EPM1270T144I5N, sometime the circuit for like the pin is in high impedance and others the pin is in a state indeterminate.
Has someone already see this probleme or know it ?
Thank you.
    What do you mean by perturbated ?
    In your schema, the net_31 will not go higher than {3.3V + VLed}.
    If CPLD was not connected,
    your Led will emitting light if TS> {3.3V + VLed}
    if TS < {3.3V + VLed}, no source drives the net_31.
    The voltage level of net_31 would depend of Ts with R and design of the AOP (Operationnal Ampli), and it would be too sensitive.
    To resume : if ts=0, net_31 is unknown.
    Here, Led is functionning as a clamping Diode : is it exactly what you want ? (not sure)
    Check carefully your CPLD pins option.
    Try also / look at :
    - unused input tri-stated pin option in Quartus (if you are using Quartus)
    - inout pin
    - open drain pin
    This is the part of the schéma where is the problem.
    The connection net_31 pass on a pin of the CPLD in the routing.
    This pin is declared in HZ because I don't want the signal to be perturbed.
    Look at http://www.alteraforum.com/forum/showpost.php?p=76202&postcount=1 I think it is similar.
    I pass signals under ? the CPLD by some pins. Do you mean that HZ pins are connected to your "signals under the CPLD " ?
    I declare those pins in HZ for they don't influence the signals.
    "don't influence" : It depends of impedance of your signal generator.
    Are you sure of your connections CPLD_pin <--> "under CPLD" signals? :-)
    Could you give a simple schema of your design {CPLD + extern} ?
    Your english is not perfect ;-).
    I have create a electronic circuit but because I haven't have much space, I pass signals under the CPLD by some pins.
    My problem is sometimes the signals pass without problem and others the signals are Perturbed.
    How do you check if HZ is in high impedance ?
    I mean what circuit do you use to determine "high impedance" on those pins ?
    Indeterminated state : do you mean it is sometimes 0 and other times it is 1 ?
    Many chips have a internal weak pull-up resistor on their pins.
    Like I have write in my message my pin is "out" then it's a output.
    I don't read the pin but I have declare it in a 'Z' state because I have a signal routing here.
    I considere my pin in 'Z' state when she doesn't influence my signal.
    The question is unclear. What do exactly mean with "a state indeterminate". In my opinion it only exists in a simulation, flagged as 'U'. 'Z' state can only exist for an output signal, so where do you read the indeterminate state?
