15 years agoProblème programmation Pin
Hello, For the passage of a signal, I use a pin in High Impedance, I declare it with : HZ : out std_logic_vector(11 downto 0); HZ<="ZZZZZZZZZZZZ"; My problem is with...
15 years agoThis is the part of the schéma where is the problem.
The connection net_31 pass on a pin of the CPLD in the routing. This pin is declared in HZ because I don't want the signal to be perturbed.
