15 years agoProblème programmation Pin
Hello, For the passage of a signal, I use a pin in High Impedance, I declare it with : HZ : out std_logic_vector(11 downto 0); HZ<="ZZZZZZZZZZZZ"; My problem is with...
15 years agoHi,
How do you check if HZ is in high impedance ? I mean what circuit do you use to determine "high impedance" on those pins ? Indeterminated state : do you mean it is sometimes 0 and other times it is 1 ? Many chips have a internal weak pull-up resistor on their pins.
