15 years agoProblème programmation Pin
Hello, For the passage of a signal, I use a pin in High Impedance, I declare it with : HZ : out std_logic_vector(11 downto 0); HZ<="ZZZZZZZZZZZZ"; My problem is with...
15 years agoHi,
I have create a electronic circuit but because I haven't have much space, I pass signals under the CPLD by some pins. I declare those pins in HZ for they don't influence the signals. My problem is sometimes the signals pass without problem and others the signals are Perturbed.
