15 years agoProblème programmation Pin
Hello, For the passage of a signal, I use a pin in High Impedance, I declare it with : HZ : out std_logic_vector(11 downto 0); HZ<="ZZZZZZZZZZZZ"; My problem is with...
15 years agoHi,
Look at http://www.alteraforum.com/forum/showpost.php?p=76202&postcount=1 I think it is similar. I pass signals under ? the CPLD by some pins. Do you mean that HZ pins are connected to your "signals under the CPLD " ? I declare those pins in HZ for they don't influence the signals. "don't influence" : It depends of impedance of your signal generator. Are you sure of your connections CPLD_pin <--> "under CPLD" signals? :-) Could you give a simple schema of your design {CPLD + extern} ? Your english is not perfect ;-).
