PLL clock input freq range
Hi All ,
I have a question about PLL clock input freq range In the Fitter report , we can see the suggested range of Input Freq What will happen if the actual input frequency is out of that range ? Could the PLL work normally as usual ? Thanks9 Replies
Look for AN367: implementing PLL reconfiguration in Stratix II devices I learn about the PLL reconfiguration from this document. It is very useful. - Altera_Forum
I see , I know very little about PLL reconfiguration
By the way , I could not find documents about the PLL reconfig could you please give me the link Thanks very much for your help !!! - Altera_Forum
First we'll see if one setting will cover the range you desire. If not we will need to use multiple settings and PLL reconfiguration as FPGA_Guy suggested earlier.
You're welcome. There are roughly 16,000 different PLL settings so I would suggest to try different settings. I can help you manually pick settings to see if we can do better than what Quartus II is choosing. I'll need to know your PLL requirements and settings that you entered into Quartus II.
Hi Justin ,
Thanks for your answer I have a question further If I have a frequency input range of 266MHz to 400MHz And in the fitter report , it shows the Stratix II PLL could only receive input clock signal from 300MHz to 500MHz what should I do to ensure the PLL could work properly @ 266MHz ? Thanks - Altera_Forum
PLL will lose lock if the clock edge mis-alignment between the input clock and the feedback clock exceed the lock window. The lock window can be calculated. It may also be reported in the PLL settings in the report file generated by QII. So, it can lose lock if the frequency is too far away from the actual specified frequency. How much is too far, well you have to exceed the lock range for each frequency setting. Data may be available in characterization reports by contacting Altera. Also, you may lose lock if the clock uncertainty (function of jitter components) exceeds the lock window.
You may get a lock on a few devices because the range has some guard band. THis is not guaranteed for every device or across temperature.
Can you use PLL reconfiguration? - Altera_Forum
In Practical cases ,
It seems it works normally Under what conditions will the PLL loses lock ? Thanks - Altera_Forum
if you're out of that range, your pll could lose lock.
