14 years agoPin Planner: Can't edit the current device because the device is read-only
Under QuartusII, V12, Pin Planner, I can't plan any pins (modify pin location). error=Can't edit the current device because the device is read-only". Each time I compile the design the .pin file is overwritten so editing the .pin file is not an option. Under QuartusII>Projects>Add/remove_files_in_project>settings, I see no applicable setting. Online Altera guidance for the Pin Planner targets some old tool so nothing stated matches what I see in the QuartusII V12 Pin Planner. Does anyone know a way to bypass the pin planner and edit a file to map my FPGA pin functions as currently wired on my PCB? (I've lodged an SR 10870876 and will share any resulting wisdom) Thanks.4 Replies
Pin Planner assignment Problem solved...
a) Realization: Pin Planner is nothing more than a viewer for end results. b) The correct format of the Tcl, despite the example from [Tcl_Console]>help -examples is as follows. (PIN_name followed by SIGNAL_name) -----snippet------------# QuartusII>View>Utilty_windows>tcl_console# >source maestro_pin.tcl# Assignment Editor will show# To AssignmentName Value Enabled# debug_spi_sclk_0 Location PIN_B12 Yes set_location_assignment -to PIN_b12 debug_spi_sclk_0 set_location_assignment -to PIN_f12 debug_spi_syn_n_0 set_location_assignment -to PIN_c18 fpga_usb_uart_cts . . export_assignments -----end snippet---------- Notes: 1. The Assignment editor shows a check mark on each row no matter what nonsense text the Tcl script enters. 2. QuartusII>Project>Generate_Tcl_file_for_project is handy to capture any manual mods made in Assignment Editor. - Altera_Forum
--- Quote Start --- b) Tcl is the way to go. --- Quote End --- Most definitely. --- Quote Start --- I'm not quite there but I'm close: Tcl prompt....QuartusII>View>Utility_windows>Tcl_console Tcl script.....>source myscript.tcl After running myscript.tcl and compiling my VHDL I can see a) Under QuartusII>Assignment_editor that all my pin locations were accepted correctly and without complaint. b) Under Pin Planner I see every pin assignment in the assignment editor was ignored. --- Quote End --- Did you synthesize the design after applying the constraints? I'm not sure that the GUI windows mean anything until Quartus has had a chance to apply the settings to your design. --- Quote Start --- Some things that don't work... 1. despite Altera documentation of the tcl console saying otherwise >quartus_sh -t myfile.tcl does not work --- Quote End --- In what way? I've used it in the past and it works. You have to have your Tcl script create or open a project, and then you can create assignments that ultimately go in the .qsf file for the project. However, you can consider that .qsf file a 'generated' file and delete it at any time, since your Tcl script will regenerate it. Try running one of the synth.tcl scripts I created using quartus_sh. If it doesn't work, let me know and I'll fix it so that it works, and then you can use that as your reference script. Cheers, Dave - Altera_Forum
Dave,
Thanks, I right away learnt two things from your post a) Search on "pin assignment: not "pin planner" b) Tcl is the way to go. I'm not quite there but I'm close: Tcl prompt....QuartusII>View>Utility_windows>Tcl_console Tcl script.....>source myscript.tcl After running myscript.tcl and compiling my VHDL I can see a) Under QuartusII>Assignment_editor that all my pin locations were accepted correctly and without complaint. b) Under Pin Planner I see every pin assignment in the assignment editor was ignored. ---snippet---------# QuartusII>View>Utilty_windows>tcl_console# >source maestro_pin.tcl# set_global_assignment -name family CYCLONE V# set_global_assignment -name device 5CGXFC7C7F23C8 set_location_assignment -to PIN_b12 debug_spi_sclk_0 set_location_assignment -to PIN_f12 debug_spi_syn_n_0 set_location_assignment -to PIN_c18 fpga_usb_uart_cts etc... ---end snippet--------- Some things that don't work... 1. despite Altera documentation of the tcl console saying otherwise >quartus_sh -t myfile.tcl does not work 2. the .qsf file QuickScriptEditor...no hits when search its help for "Pin" or "assignment". Search on "the" was sucessful :). Conclusion=.qsf files editor won't help me. - Altera_Forum
--- Quote Start --- Does anyone know a way to bypass the pin planner and edit a file to map my FPGA pin functions as currently wired on my PCB? --- Quote End --- I can't comment on your pin planner issues, as I never use it. Here's examples with Tcl scripts that perform pin assignments. http://www.alteraforum.com/forum/showthread.php?t=35687 http://www.alteraforum.com/forum/showthread.php?t=33462 http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave
