14 years agoPin Planner: Can't edit the current device because the device is read-only
Hello, Under QuartusII, V12, Pin Planner, I can't plan any pins (modify pin location). error=Can't edit the current device because the device is read-only". Each time I compile th...
14 years agoPin Planner assignment Problem solved...
a) Realization: Pin Planner is nothing more than a viewer for end results. b) The correct format of the Tcl, despite the example from [Tcl_Console]>help -examples is as follows. (PIN_name followed by SIGNAL_name) -----snippet------------# QuartusII>View>Utilty_windows>tcl_console# >source maestro_pin.tcl# Assignment Editor will show# To AssignmentName Value Enabled# debug_spi_sclk_0 Location PIN_B12 Yes set_location_assignment -to PIN_b12 debug_spi_sclk_0 set_location_assignment -to PIN_f12 debug_spi_syn_n_0 set_location_assignment -to PIN_c18 fpga_usb_uart_cts . . export_assignments -----end snippet---------- Notes: 1. The Assignment editor shows a check mark on each row no matter what nonsense text the Tcl script enters. 2. QuartusII>Project>Generate_Tcl_file_for_project is handy to capture any manual mods made in Assignment Editor.
