14 years agoPin Planner: Can't edit the current device because the device is read-only
Hello, Under QuartusII, V12, Pin Planner, I can't plan any pins (modify pin location). error=Can't edit the current device because the device is read-only". Each time I compile th...
14 years ago --- Quote Start --- Does anyone know a way to bypass the pin planner and edit a file to map my FPGA pin functions as currently wired on my PCB? --- Quote End --- I can't comment on your pin planner issues, as I never use it. Here's examples with Tcl scripts that perform pin assignments. http://www.alteraforum.com/forum/showthread.php?t=35687 http://www.alteraforum.com/forum/showthread.php?t=33462 http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave
