14 years agoPin Planner: Can't edit the current device because the device is read-only
Hello, Under QuartusII, V12, Pin Planner, I can't plan any pins (modify pin location). error=Can't edit the current device because the device is read-only". Each time I compile th...
14 years ago --- Quote Start --- b) Tcl is the way to go. --- Quote End --- Most definitely. --- Quote Start --- I'm not quite there but I'm close: Tcl prompt....QuartusII>View>Utility_windows>Tcl_console Tcl script.....>source myscript.tcl After running myscript.tcl and compiling my VHDL I can see a) Under QuartusII>Assignment_editor that all my pin locations were accepted correctly and without complaint. b) Under Pin Planner I see every pin assignment in the assignment editor was ignored. --- Quote End --- Did you synthesize the design after applying the constraints? I'm not sure that the GUI windows mean anything until Quartus has had a chance to apply the settings to your design. --- Quote Start --- Some things that don't work... 1. despite Altera documentation of the tcl console saying otherwise >quartus_sh -t myfile.tcl does not work --- Quote End --- In what way? I've used it in the past and it works. You have to have your Tcl script create or open a project, and then you can create assignments that ultimately go in the .qsf file for the project. However, you can consider that .qsf file a 'generated' file and delete it at any time, since your Tcl script will regenerate it. Try running one of the synth.tcl scripts I created using quartus_sh. If it doesn't work, let me know and I'll fix it so that it works, and then you can use that as your reference script. Cheers, Dave
