14 years agoPin Planner: Can't edit the current device because the device is read-only
Hello, Under QuartusII, V12, Pin Planner, I can't plan any pins (modify pin location). error=Can't edit the current device because the device is read-only". Each time I compile th...
14 years agoDave,
Thanks, I right away learnt two things from your post a) Search on "pin assignment: not "pin planner" b) Tcl is the way to go. I'm not quite there but I'm close: Tcl prompt....QuartusII>View>Utility_windows>Tcl_console Tcl script.....>source myscript.tcl After running myscript.tcl and compiling my VHDL I can see a) Under QuartusII>Assignment_editor that all my pin locations were accepted correctly and without complaint. b) Under Pin Planner I see every pin assignment in the assignment editor was ignored. ---snippet---------# QuartusII>View>Utilty_windows>tcl_console# >source maestro_pin.tcl# set_global_assignment -name family CYCLONE V# set_global_assignment -name device 5CGXFC7C7F23C8 set_location_assignment -to PIN_b12 debug_spi_sclk_0 set_location_assignment -to PIN_f12 debug_spi_syn_n_0 set_location_assignment -to PIN_c18 fpga_usb_uart_cts etc... ---end snippet--------- Some things that don't work... 1. despite Altera documentation of the tcl console saying otherwise >quartus_sh -t myfile.tcl does not work 2. the .qsf file QuickScriptEditor...no hits when search its help for "Pin" or "assignment". Search on "the" was sucessful :). Conclusion=.qsf files editor won't help me.
