physical interface between Cyclone III & DAC
Hello to all,
I am working on a test waveform generator project using the Cyclone III starter kit (3C25N). Once synthesized on the FPGA, the waveform will be sent to a DAC so that it can be viewed using an oscilloscope. I'm using the TI DAC5672 eval module which has a 34-pin header for input. Is there any way I can physically interface the DAC with the FPGA? I've worked with an FPGA before but never on interfacing a DAC with it. Extensive google searches did not turn up anything useful. Thanks in advance for the help.20 Replies
Oops! I meant ad9767
--- Quote Start --- Actually I was referring to the Terasic Board which has an on-board DAC. I've attached the manual for it (refer to Page 8). The Analog Devices DAC9797 used in the board can be both AC & DC coupled. But I'm not sure why the Terasic board says no DC signalling. --- Quote End --- You need to look at the schematic, not the user manual. Its likely the schematic has a transformer output. The DAC output is a current. Its much easier for evaluation board developers to put termination resistors and a transformer on the output, than it is to put a wide bandwidth amplifier that preserves DC. There are not many devices that will do that, eg. a wideband op-amp, most RF amplifiers are AC-coupled devices. These are high-speed DACs, and are generally not used in applications requiring a DC value. Cheers, Dave - Altera_Forum
--- Quote Start --- These are high-speed DACs, and are generally not used in applications requiring a DC value. --- Quote End --- I don't agree. This sounds like high speed DACs (and also ADCs) won't be suited for wideband DC capable applications. But they surely are, and a lot of applications is relying on their DC specification. The Terasic THDB_ADA board (as well as several Altera DSP DevKits) is apparently targetting to "passband" RF applications that don't need DC capability. For these, transformer coupling is the most simple (and cheapest) way to achieve good performance. I noticed, that the AC coupling of these DevKits is unsuitable for many users, who are dealing with wideband DSP applications. It's easy to remove the transformers, and the boards already have jumper options to DC couple the ADC and DAC analog interfaces. But particularly the high end DevKits won't look bad with a state-of-the-art DC capable interface. The transformer interface could be still provided as an assembly option. - Altera_Forum
--- Quote Start --- But particularly the high end DevKits won't look bad with a state-of-the-art DC capable interface. --- Quote End --- What would you suggest as a state-of-the-art DC capable interface? These DACs are current output devices, so you'd need a wideband current-to-voltage circuit involving probably a current-feedback op-amp (CFA) or voltage-feedback op-amp (VFA) op-amp circuit (or termination resistors and a buffer op-amp). You'd want good DC offset performance ... I vaguely recall CFAs aren't that brilliant in that area, but I haven't looked for a while. What would be the maximum bandwidth of this DC coupled system, and what number-of-bits of dynamic range could the DAC generate? What are examples of wideband DSP applications that involve DC (other than oscilloscope type applications)? The wideband applications I deal with all involve RF amplifiers, which are inherently AC-coupled. So I'm just interested in what others are doing. Cheers, Dave - Altera_Forum
Many kinds of test and measurement systems, e.g. arbitrary waveform generators will require DC coupled DAC outputs. The portfolio of major instrument vendors can tell about state-of-the-art.
Personally, I have implemented systems up to 16 Bit / 500 MSPS. Other than for a communication application, you don't necessarily require the full effective bitwidth at high frequencies. But you want precise high speed waveforms in time domain and high amplitude resolution at lower frequencies. That means, you can e.g. afford to generate the DAC clock from a FPGA, which would be incredible in the RF world. Amplifiers are often CFA or fully differential types. - Altera_Forum
--- Quote Start --- Many kinds of test and measurement systems, e.g. arbitrary waveform generators will require DC coupled DAC outputs. The portfolio of major instrument vendors can tell about state-of-the-art. Personally, I have implemented systems up to 16 Bit / 500 MSPS. Other than for a communication application, you don't necessarily require the full effective bitwidth at high frequencies. But you want precise high speed waveforms in time domain and high amplitude resolution at lower frequencies. That means, you can e.g. afford to generate the DAC clock from a FPGA, which would be incredible in the RF world. Amplifiers are often CFA or fully differential types. --- Quote End --- Thanks! Cheers, Dave - Altera_Forum
--- Quote Start --- It's easy to remove the transformers, and the boards already have jumper options to DC couple the ADC and DAC analog interfaces. --- Quote End --- I was able to successfully set up the interface between the DAC and the FPGA. So thanks for the all the help/suggestions on that part. I am trying to implement some form of offset control at the output of the DAC. Since the output is AC-coupled I'm going to remove the transformer and solder 2 surface-mount resistors on the Terasic board. Is that what you meant by jumper options? - Altera_Forum
--- Quote Start --- Is that what you meant by jumper options? --- Quote End --- Yes. More exactly, for channel A, you need to desolder T5 and place a zero ohm jumper or a piece of wire for R60. R61 won't be mounted, because this DAC output is out of phase and would cancel the output signal, if connected. Doing so, you get a 0 - 1 V unipolar output. - Altera_Forum
I'm trying to implement a PID controller on my Cyclone III Starter Kit with attached DAC and so I'm looking for a way to output positive or negative DC voltages (-1 to 1 volts, say). Is there any way to modify the DAC on the DAC in order to achieve this output? Also, is there any way to modify the ADC to read in a DC voltage?
Thanks! - Altera_Forum
Originally Posted by FvM
The breakout board that I know (the one documented with the Cyclone III c120 development kit) has a serious disadvantage: It hasn't any ground pins at the debug header. I don't think it's particularly suited to connect single-ended high speed signals.
Oh man, that's bogus ... but you are right. Attached is the breakout header schematic that was delivered with the Stratix IV GX development kit.
Perhaps the HSMC to GPIO breakout board would be better then. The original poster can download the schematic for that.
Thanks Frank!
Cheers,
Dave
