15 years agophysical interface between Cyclone III & DAC
Hello to all, I am working on a test waveform generator project using the Cyclone III starter kit (3C25N). Once synthesized on the FPGA, the waveform will be sent to a DAC so that it can be vi...
15 years ago --- Quote Start --- Actually I was referring to the Terasic Board which has an on-board DAC. I've attached the manual for it (refer to Page 8). The Analog Devices DAC9797 used in the board can be both AC & DC coupled. But I'm not sure why the Terasic board says no DC signalling. --- Quote End --- You need to look at the schematic, not the user manual. Its likely the schematic has a transformer output. The DAC output is a current. Its much easier for evaluation board developers to put termination resistors and a transformer on the output, than it is to put a wide bandwidth amplifier that preserves DC. There are not many devices that will do that, eg. a wideband op-amp, most RF amplifiers are AC-coupled devices. These are high-speed DACs, and are generally not used in applications requiring a DC value. Cheers, Dave
