15 years agophysical interface between Cyclone III & DAC
Hello to all, I am working on a test waveform generator project using the Cyclone III starter kit (3C25N). Once synthesized on the FPGA, the waveform will be sent to a DAC so that it can be vi...
15 years ago --- Quote Start --- But particularly the high end DevKits won't look bad with a state-of-the-art DC capable interface. --- Quote End --- What would you suggest as a state-of-the-art DC capable interface? These DACs are current output devices, so you'd need a wideband current-to-voltage circuit involving probably a current-feedback op-amp (CFA) or voltage-feedback op-amp (VFA) op-amp circuit (or termination resistors and a buffer op-amp). You'd want good DC offset performance ... I vaguely recall CFAs aren't that brilliant in that area, but I haven't looked for a while. What would be the maximum bandwidth of this DC coupled system, and what number-of-bits of dynamic range could the DAC generate? What are examples of wideband DSP applications that involve DC (other than oscilloscope type applications)? The wideband applications I deal with all involve RF amplifiers, which are inherently AC-coupled. So I'm just interested in what others are doing. Cheers, Dave
