15 years agophysical interface between Cyclone III & DAC
Hello to all, I am working on a test waveform generator project using the Cyclone III starter kit (3C25N). Once synthesized on the FPGA, the waveform will be sent to a DAC so that it can be vi...
15 years ago --- Quote Start --- Is that what you meant by jumper options? --- Quote End --- Yes. More exactly, for channel A, you need to desolder T5 and place a zero ohm jumper or a piece of wire for R60. R61 won't be mounted, because this DAC output is out of phase and would cancel the output signal, if connected. Doing so, you get a 0 - 1 V unipolar output.
