10 years agoOutput Linux´s Video to VGA controller in FPGA Fabric through AXI on CV SoC
Hi all,
I designed a custom expansion board for the de0 nano SoC with an AD 7123 video DAC and a wolfson audio dac. I have an VGA controller running fine on the FPGA fabric side (driving the AD7123) but now i need to output the video from linux to the VGA controller (Angstrom´s X-Windows). I have high level on c programming but i´m not an expert in Linux Kernel Driver development. Somebody can help me ? I know it´s not very easy to do ... Thanks in advance.18 Replies
--- Quote Start --- Hi, it is not really necessary at normal resolution, if you wish have full HD or 4HD then a separate memory is better due memory channel bandwidth reduce processor speed too. Memory of HPS can be accessed from FPGA and FPGA memory controller can be accessed from HPS too. Which IP did you used for your design and how are they interconnected on QSYS? --- Quote End --- I wrote the code by hand ! Its not connected to qsys, i have two versions, fifo and axi but now it runs freely without bus connection. I placed a post in the general topics for asking forum members to a group purchase of mi next evaluation board you can see a picture of the board I designed a verilog axi slave for acces the adc from linux, it runs fine and you can full configure it, i can pass you the code if you want - Altera_Forum
--- Quote Start --- I wrote the code by hand ! Its not connected to qsys, i have two versions, fifo and axi but now it runs freely without bus connection. I placed a post in the general topics for asking forum members to a group purchase of mi next evaluation board you can see a picture of the board I designed a verilog axi slave for acces the adc from linux, it runs fine and you can full configure it, i can pass you the code if you want --- Quote End --- Good Idea, just check if this don't infringe forum rules, I am quite new and we need read FAQ or ask moderator, also ask Terasic for, Maybe I got interested to use DE0 Nano instead of DE1_SOC, just a question, why VGA when all new monitor are switching to HDMI? About code, I can take an eye and try port to QSYS to share if you wish, this can improve the usability of your "cape". (Cape is the add on of Beagle Bone as for shield of arduc and boosterpak of TI, nothing to do with Terasic simply call "Daughter card") After a long time coding by hand I decided to learn how QSYS work and now a lot of my module are near ported to. It is a valuable tool and save a lot of time on connecting layer. Some drawback are still on, Linux version is plagued by a bug on graphical and sometimes PLL IP must be edited by hand, this is not a problem, as for Linux when GUI doesn't work or don't know how to I just edit config files script or just do some command line actions. IMHO switch layer from processor and peripheral can be optimized to reduce silicon usage, but it work and for now things fit on selected size with some small margin. PS: remember to use time compensated design on PCB artwork. - Altera_Forum
`define DZERO_GREATER 2
`define ADC_CONVST_CYCLES ( 10 - `DZERO_GREATER ) `define WAIT_CYCLES 5 `define TRANSFER_CLOCKS (12) `define SCK_ON ( `ADC_CONVST_CYCLES + `WAIT_CYCLES ) `define SCK_OFF ( `SCK_ON + `TRANSFER_CLOCKS ) `define SHIFT_OFF (`SCK_ON + 6 ) module ltc2308 ( clk,go,ADC_SDO,chansel, ADC_CONVST,ADC_SCK,ADC_SDI,done,data ); input clk,go,ADC_SDO; input [3:0] chansel; output ADC_CONVST,ADC_SCK,done; output reg ADC_SDI; output reg[11:0] data; //////////////////////////////////////////////////////////////////////// //Generates negative reset_p pulse signal at go signal posedge. //////////////////////////////////////////////////////////////////////// wire resetp; reg rstbegin; assign resetp = ( (rstbegin == 1'b0) && (go == 1'b1) )? 1'b0 : 1'b1; always@(posedge clk) begin rstbegin <= go; end //////////////////////////////////////////////////////////////////////// //CFG bits at resetp //////////////////////////////////////////////////////////////////////// reg [5:0] cmd; always@(negedge resetp) begin cmd <= { chansel, 2'b10}; end //////////////////////////////////////////////////////////////////////// //Cycle counter //////////////////////////////////////////////////////////////////////// reg [7:0] counter; assign ADC_CONVST = (counter>`ADC_CONVST_CYCLES)? 1'b0 : 1'b1; always@(posedge clk or negedge resetp) begin if(resetp==1'b0) counter <= 8'b0; else if(done == 1'b0) counter <= counter + 1'b1; end //////////////////////////////////////////////////////////////////////// //SCK //////////////////////////////////////////////////////////////////////// reg sckon; assign ADC_SCK = (sckon==1'b1)? clk : 1'b0; always@(negedge clk or negedge resetp) begin if(resetp==1'b0) sckon <= 1'b0; else if ( (counter>=`SCK_ON && counter<`SCK_OFF) ) sckon <= 1'b1; else sckon <= 1'b0; end //////////////////////////////////////////////////////////////////////// //RX //////////////////////////////////////////////////////////////////////// reg [3:0] irx; assign done = (irx > (`TRANSFER_CLOCKS - 1) )? 1'b1 : 1'b0; always@(negedge clk or negedge resetp) begin if(resetp==1'b0) begin data <= 12'b0; irx <= 4'b0; end else if ( sckon == 1'b1 ) begin irx <= irx + 1'b1; data[11-irx] <= ADC_SDO; end end //////////////////////////////////////////////////////////////////////// //TX //////////////////////////////////////////////////////////////////////// reg [2:0] itx; always@(negedge clk or negedge resetp) begin if(resetp==1'b0) begin itx <= 3'b0; ADC_SDI <= 1'b0; end else if ( (counter >= `SCK_ON) && (counter < `SHIFT_OFF) ) begin itx <= itx + 1'b1; ADC_SDI <= cmd[5-itx]; end else ADC_SDI <= 1'b0; end endmodule what means "time compensated design" ? I use vga because it´s easy to find a cheap "second hand" monitor for use with fpga and almost all people haves one vga monitor ... But i will add hdmi too !! I like qsys so much i enjoy a lot designing my own system i love this architecture, now i have a nios on the fpga side and the system its similar to the I.MX6 soloX with the cortexA + cortex M but with a lot of flexibility, i´m designing a board with the cheaper cyclone V soc i found at mouser 5CSEBA2U19C86N [h=1][/h] - Altera_Forum
Hi nachodizz990, Hmmm i am not so proficient in Verilog due I am prevalent VHDL developer but at glance this code seems an ADC module interface than video...
About high speed design you need compensate for both impedance and time of fly, all signal must arrive at same time to DDR Chip. try these if you like video or recommendation about DDR wiring: in first this is related to RF and High speed, DDR are High speed and if lines impedance is not adapted they become RF transmitters too. https://www.youtube.com/watch?v=6jrvzu7eqiw This is a lesson on how to route an High Speed LVDS track. https://www.youtube.com/watch?v=blhlmq2ho1w https://www.youtube.com/watch?v=41r3kkm_fme your tools resemble Altium so check also this on length compensation https://www.youtube.com/watch?v=bzrdfcjilga If you like readable document or a book I can post reference. Regards - Altera_Forum
Yes, i know , lenght matching!
I know Robert Feranec and Fedevel, i´ve seen all their videos some time ago... - Altera_Forum
--- Quote Start --- Yes, i know , lenght matching! I know Robert Feranec and Fedevel, i´ve seen all their videos some time ago... --- Quote End --- I seen few minutes before to post and I like them, I am more incline to document but sometimes I also watch some lesson. The Analog Device too is a good tutorial on how plane work and RF, take an Eye. About DDR on daughter board I fear there where not enough pin, some need to be free for user interaction, a better solution, as I asked ,was just to use HDMI: it can consume just 4 LVDS pair and one PLL, you can deserialise HDMI with a chip, fed VGADAC then analog monitor, if you do that on a short adapteur signal integrity can be better. Anyway this has sense on old analog CRT monitor, if you own an LCD analog input is first converted to digital then fed serially to LCD panel on parallel or HDMI Like Lvds serial port. - Altera_Forum
Thanks , i´m planing to remove the 7 seg and add one joystick and some pushbuttons (like gamepad) and leds...
The 7 seg fills a lot of space and it´s not so usefull... I will place a ddr1 or sram (x16 only) mem because the header connection its dangerous for ddr3. In addition the pcb tracks from the soc to the headers have unknow lenght and impedance because they are not designed to be a memory bus, so i need to use sram or ddr1 as much ... I will make two versions, one for the nano soc with ddr and other for the nano without ddr because it includes onboard ddr. Furthermore if i only make one board this will not feet perfect with both nanos I have enought idle pins the other header is fully empty What is your opinion? Your idea is to transmit hdmi from fpga to ad 9980 and then feed the 7123 wit the 9980´s output? The main concern it´s that both chips are expensive ... And what about use only the 7123 and people who has not vga monitor use an vga to hdmi adapter? Or dont use any ad chip and feed the hdmi directly from fpga and place and vga conector too but with 5 bits r-ladder dac If we have fpga why use an 9980 like chip, we can make it in hdl ... Send me your mail for discuss the layout if you like... - Altera_Forum
--- Quote Start --- Thanks , i´m planing to remove the 7 seg and add one joystick and some pushbuttons (like gamepad) and leds... The 7 seg fills a lot of space and it´s not so usefull... ........... I have enought idle pins the other header is fully empty What is your opinion? .... --- Quote End --- No problem send you my email, I prefer remain here so other can contribute to development and or wish list. My idea can be to make some piggy back so one can add what it like, one board for memory has length and time constraint too so just the memory on board then plug other interfaces to top that can bbe everything. Ex LCD TFT + Key + Joy 16x2 LCD + key + joy ADC DAC Motor Interface.. Just what you think can be added on a stack as it is on Beagle Board (Black-) --- Quote Start --- Your idea is to transmit hdmi from fpga to ad 9980 and then feed the 7123 wit the 9980´s output? The main concern it´s that both chips are expensive ... And what about use only the 7123 and people who has not vga monitor use an vga to hdmi adapter? Or dont use any ad chip and feed the hdmi directly from fpga and place and vga conector too but with 5 bits r-ladder dac If we have fpga why use an 9980 like chip, we can make it in hdl ... Send me your mail for discuss the layout if you like... --- Quote End --- My idea was to leave board with HDMI using few pin pairs, impedance is not correct but can be close and a very short stub refelect also a small amount of energy. On the other side of HDMI you can build an universal HDMI 2 VGA and it can be used for every monitor. You can provide also an LCD TFT standard 40 pin connector to use for parallel TFT. We can develop just using a small MAX V. See you, my time slot now is terminated see you soon. Roberto
